Assembly gets blocked when I make a pattern. (Inventor 2023)
diegogarzaro96
diegogarzaro96
I was doing a ball bearing assembly but when I pattern the ball everything gets blocked in the assembly. I tried doing a new assembly with only the ball. If it doesn't have a constraint it can be moved but when I add just one constraint it gets completely blocked.  I
Accepted solutions (3)
throttle1253Z225
This same exact data set has came about here lately lol.. Make sure you have the latest updates installed as there was a known issue about the free move early on. That should fix your issue.
Have a great day!
blandb
If that solves your issue, pleases use this one not the one above, as it switched my account on accident. Thanks
Autodesk Certified Professional
johnsonshiue
Hi! Yes, this is a known regression in 2023.0. Please install 2023.0.1 update. It should address this issue and other stability related issues.
Many thanks!
Software Test Engineer
