Assembly constraint
Assembly constraint
hello everyone. i tried to assemble polyethylene part so that it will slide on talar comp but it keep on rotating.i tried to fix it but still could not make it.do anyone know what constrain should i use to solve this ? any help will be appreciated.
johnsonshiue
Hi! Did you study the solution I provided in the following thread?
https://forums.autodesk.com/t5/inventor-forum/surface-assembly/m-p/9605205
I created a zero offset surface. And, apply the transitional constraint between the moving part and the offset surface (invisible). This helps control the scope of transition.
Many thanks!
Software Test Engineer
hi @johnsonshiue , i studied your solution the other day.Then  i updated my design and try to redo the assembly like you did. The polyethylene part did manage to slide,but it also can rotate through the talar comp. i just want to constrain so that it will not move through talar comp
johnsonshiue
Hi! I explicitly mentioned that you need to create the transitional constraint between the zero-offset surface (invisible) in the Tarlaw part and the bottom face of Polyethylene. You need to make the surface visible -> create the constraint -> make it invisible.
Could you try it?
Many thanks!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
