assembly comstaints failure
mostafamahmoudseddek94
Greetings
In the master assembly, I have a bunch of failed constraints after configuring it
Is there any helpful tool to use or methodology to follow in order to know the appropriate action to be taken ?
mdavis22569
Can you share the model / files?
There are quite a few possible reasons for this.
Is there an issue already in the assembly ( red cross lite up) ?
What happens if you do a Rebuild All under the Manage Tab, does it come back with issues?
Mike Davis
johnsonshiue
Hi! I believe the constraints were created before you turn the individual parts into iParts, right? If yes, this is because the iPart members are derived parts to the iPart factory. The face IDs in the iPart members are different than the one in the factory.
To keep the constraint relaitionship, you should create iMates instead. iMates can propagate from iPart factory to the iPart members. When you switch from one member to another, the iMates will survive and the constraints will not go sick. If you cannot figure it out how to do it, please share an example here. Forum experts can take a look and provide guidance.
Many thanks!
Software Test Engineer
lena.talkhina
Hello @mostafamahmoudseddek94  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
