- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear all,
currently I'm trying to join a pillow block to a frame selecting two surfaces (mate), but unfortunately I always get the message "assembly can't be solved" when I hit apply. I tried with "Joint" as well as "Constrain". You can find the project attached. Would somebody be so kind and give this a look?
My goal is to attach the bottom surface of the pillow block to the frame as shown in the screenshot. I have marked two points on the pillow block and two on the frame which I later want to use to bolt them together with the Bolted Connection feature.
Thanks so much,
Lalit
