I was following the demo by @Neil_Cross on YouTube for angular constraint limits but ran into issues when I want to have asymmetric angular limits beyond 180 degrees. I can't share my project but have attached a demo hinge to show what I mean.
Say I want my blue beam to be in-line with my red beam and travel the long arc up to the 210 degree angle.
(A second scenario is where I want the blue beam to be +30 to -120 degrees from aligned with the beam).
1) Inventor won't let me enter a Maximum limit of 210 degrees
2) If I enter a smaller Maximum e.g. 120 degrees (with Min=0) then the constraint is applied symmetrically so that the blue beam can move PLUS and MINUS 120 degrees from zero.
Is this bad implementation or am I just using it wrongly? How would I limit the angular constraint for large angles (above 180 degrees) and for asymmetric limits?
NOTE: Inventor allows vectors to be entered (i.e. negative angles) but always treats them as positive.
