Assembly Angular Constraint Limits - Large Angles and Asymmetric Limits
SEC_MECH
Message 1 of 8
SEC_MECH
I was following the demo by @Neil_Cross on YouTube for angular constraint limits but ran into issues when I want to have asymmetric angular limits beyond 180 degrees. I can't share my project but have attached a demo hinge to show what I mean.
Say I want my blue beam to be in-line with my red beam and travel the long arc up to the 210 degree angle.
(A second scenario is where I want the blue beam to be +30 to -120 degrees from aligned with the beam).
1) Inventor won't let me enter a Maximum limit of 210 degrees
2) If I enter a smaller Maximum e.g. 120 degrees (with Min=0) then the constraint is applied symmetrically so that the blue beam can move PLUS and MINUS 120 degrees from zero.
Is this bad implementation or am I just using it wrongly? How would I limit the angular constraint for large angles (above 180 degrees) and for asymmetric limits?
NOTE: Inventor allows vectors to be entered (i.e. negative angles) but always treats them as positive.
Replies (7)
Message 2 of 8
swalton
I'd use the directed angle option and define a reference axis.  That will help Inventor understand what to do with angles larger than 180 deg and negative values.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 3 of 8
johnsonshiue
Hi! Steve is right. Undirected angle is only meaningful between 0 and 180. Any value beyond the range is not valid. I suggest you use Explicit Reference option so you can specify the full range (+-360). But, you need to select a rotational direction, which helps avoid flipping.
Many thanks!
Software Test Engineer
Message 4 of 8
SEC_MECH
It is not possible to use limits with Directed Angle. When Directed Angle is selected the Limits fields become greyed out and unavailable.
Undirected Angle - Limits available
Directed Angle - Limits not available
Message 5 of 8
swalton
Sorry,  I used the wrong name for the angle option.
I meant the Explicit Angle Reference option (right-most button).  That option allows you to define a reference vector that uses the right-hand-rule to define the + and - directions for the angle value.
See: https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-AD4679FD-EE9B-47C0-9E32-04B990BDD29E
Steve Walton
Inventor 2025
Message 6 of 8
SEC_MECH
This has to be a bug or a very poor implementation.
Even by using the Explicit Reference Vector I could not restrain the movements as required.
Min::Max::Expectation::Result
FAIL - 0::70::The blue beam to be limited from 0 - 70 degrees :: Beam limited to +/- 70 degrees (i.e. 140 degrees travel)
FAIL - 0.5::70:: Limit travel 0.5 - 70 degrees :: Beam limited to +/- 70 degrees (i.e. 140 degrees travel)
FAIL - 1::70:: Limit travel 1 - 70 degrees :: Beam limited to +/- 70 degrees (i.e. 140 degrees travel)
PASS - 5::70:: Limit travel 5 - 70 degrees :: Beam limited to 5 - 70 degrees from parallel
PASS - 5::170:: Limit travel 5 - 170 degrees :: Beam limited to 5 - 170 degrees from parallel
FAIL 5::180:: Limit travel 5 - 180 degrees :: Beam can travel the long arc between 5 degrees and -5 degrees from parallel (i.e. 350 degrees travel)
I cannot see a simple way to achieve the limits that I need to apply.
Message 7 of 8
imajar
See attached.  Is that what you need it to do?
I generally have had a good experience using explicit reference vector, although selecting a good vector (that is orthogonal to the angle) is essential to get it to work right.
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
Message 8 of 8
SEC_MECH
@imajar You're da man! Thank you so much for your solution. It works brilliantly with large angles and asymmetric limits. I just wish that AutoDesk would have made it more intuitive. Thank you for taking the time to post the solution.
