Inventor Forum
assembling parts
3 REPLIES 3
505 Views, 3 Replies
assembling parts
Should I use constraints, joints, or edges to assemble parts? Which is the best way to do this?
assembling parts
3 REPLIES 3
imajar
imajar
Since we don't know what you are trying to do, the answer is:  "Yes".  😁
You can use either constraints or joints (Not sure what you mean by edges).  I typically use constraints, but joints are fine too.
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
Aaron Jarrett, PE
LinkedIn
Life is Good.
It really depends what you are trying to assemble.
What do yo think ? @baliasM74U3
johnsonshiue
johnsonshiue
Hi! Inventor Constraints and Joints are solved together. Joints can be viewed as combo constraints, which reduce DOF more quickly. Constraints allow you to control DOF individually. Another difference between them is the qualified geometry. Joints only allow body geometry to participate, while Constraint allows almost all geometry types like sketches or work features.
Many thanks!
Software Test Engineer
Many thanks!
