Hey all, I have multiple assemblies in one. These all have moving arrangements but when together the become locked. Is there a way to allow these systems to work whilst in the main assembly. All the constraints/collision work in independent assembly's and the ones in the main assembly are simple.
Solved by JDMather. Go to Solution.
@a.eliah.cameron
Right click on each of the sub-assemblies and select Flexible.
If this doesn’t solve the issue then zip and Attach your assembly here.
(Have you installed all Updates for your version of Inventor?)
@a.eliah.cameron
I assume you are using Contact Sets.
Are you familiar with using 2D and 3D Contacts in Dynamic Simulation rather than using Contact Sets?
@a.eliah.cameron wrote:
Is this a more appropriate method of setting limits/collision?
Contact sets are best used between only two components at a time and then replace with Constraint/Joint Limits if appropriate. For far more realistic motion control use Environments>Dynamic Simulation Joints. But this area of Inventor is an advanced topic with a steep learning curve.
