I have very recently started using Inventor and came across an issue with arrowhead placement on a drawing. The attached picture displays a 0.25" dimension with the arrowheads placed ouside of the length. I would like to display this with the arrowheads inside the length. To do this, I checked the "Arrowheads Inside" option, yet this did not solve my issue. I found that if I varied the dimension length to be greater than 0.30", it would place the arrowheads inside but if it was smaller than 0.30" the issue would persist.
Is it possible to place the arrowheads inside with a dimension this small, and if so how do I do this?
-Joe
Solved by hossaiy. Go to Solution.
Hi Joe and welcome!
to answer your question, it is possible. I have made a video (below) showing how you can change the size of the arrow heads. However this may make the arrow heads a bit too small.
As an alternative, I have also shown another approach you might want to take (~37 seconds into the video), just in-case it hasn't already been considered.
Hope it helps.
This changes the style of all arrowheads and isn't really the solution, not that I have the solution.
But the function is just nog working correctly, when you select arrowheads inside they should move inside, even if the arrowheads don't fit, that is what it should do.
Hi! I could be wrong but I am not 100% sure your issue is the same as this old thread. Do you mind posting a new thread and sharing an example file? I thought we had a bug preventing it from working correctly. It was fixed in later releases. But, I need to confirm with your files.
Many thanks!
