Arrange solid bodies between two planes.
LeandroBarba
LeandroBarba
Hi! I'm working in a door family for Revit. I need to arrange a N number of solid bodies between two given workplanes. As it's a Revit Family it need to be parametric so i try to extrude the profile of the body and after arrange the body in the distance given by the two workplanes and in a N number of instances. The problem is that the last element get out the space area i want. How can i get it? The workplanes are the top and bottom planes of the whiter rectangle in the photo.
johnsonshiue
Hi! I think you want an uneven spaced pattern, right. There are a few ways to do that. Without recreating the pattern, you can simply use Direct Edit -> Body -> Move to relocate the top body back to the right place.
Or, you can delete the rectangular pattern. Create a sketch with three points along a line (dimension the spacing accordingly). Then create a Sketch Driven Pattern based on the points.
Many thanks!
Software Test Engineer
LeandroBarba
No, i want an even space pattern. The start point of the linear pattern that i used is the base of the solid body. I want to start the pattern in the down face of the whiter body.
LeandroBarba
Btw the second option that you gived me almost worked. I can add parametrically n object evenly spaced but the last element corresponding with the last point of the linear pattern in the sketch is intersecting the upper object. I upload a image.
johnsonshiue
Hi! Then rectangular pattern should work too. You may need to use the number of occurrences minus 1 divided by the span length to get the spacing.
Many thanks!
lena.talkhina
Hello @LeandroBarba  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
