arrange dimension to random line
infoMZUGD
Observer Observer
Message 1 of 15
infoMZUGD
Observer
Observer
see attached drawing. How is it possible to allign the dimension to the line?
Replies (14)
Message 2 of 15
kacper.suchomski
Yes, right-click when moving the dimension (before you confirm the position with the left).
Kacper Suchomski
Message 3 of 15
Alexander_Chernikov
Hi, more detailed answer with video:
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 4 of 15
infoMZUGD
Observer
Observer
Hey, thank you for your answers, but that is not what i mean. If you look at my drawing, you can see that i selected both of the outside-intersections. This causes the dimension to be in another angle, than the line of 45°.
Roy
Message 5 of 15
kacper.suchomski
Read my comment. This is the answer to your question.
Kacper Suchomski
Message 6 of 15
infoMZUGD
Observer
Observer
Right click, and then select what option form the menu?
Message 7 of 15
kacper.suchomski
Dimension Type -> Rotated
Kacper Suchomski
Message 8 of 15
JBerns
Rotated is not always available. I just tried by selecting two points without using Intersection.
Horizontal, Vertical, and Aligned are the only options in RMB > Dimension Type.
Why does one have to use Intersection option to get Rotated dimension type?
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 9 of 15
SBix26
Can you attach files or show video?  Rotated should be an option unless your picks have precluded it (such as picking a line as one end of a dimension).  What version of Inventor?
Sam B
Inventor Pro 2023.2.1 | Windows 10 Home 22H2
Message 10 of 15
johnsonshiue
Hi Jerry,
Rotate should always be available besides Vertical, Horizontal, and Align. It should just work. Maybe we got a bug here. Is this specific to a drawing or any drawing can reproduce the behavior?
Many thanks!
Software Test Engineer
Message 11 of 15
JBerns
@SBix26 ,
I was testing on a custom (non-orthographic) view.
Retested on ortho views and the Rotated option was available.
Sorry about that.
Jerry
CAD Administrator
Message 12 of 15
IgorMir
Hi Johnson,
May I ask - where the Rotate option is? Please see the attached. Or is it an option for the releases after IV2020?
Igor.
@johnsonshiue wrote:
Hi Jerry,
Many thanks!
Web: www.meqc.com.au
Message 13 of 15
IgorMir
In IV2020 I don't get the Rotate option no matter which way I select a geometry for dimensioning.
The only way the dimension can by placed parallel (aligned) to the oblique line is to create an auxiliary sketch. Unless I am missing something obvious here.
Cheers,
Igor.
Message 14 of 15
johnsonshiue
Hi Igor,
Rotate Dimension was added to Inventor 2021.
https://help.autodesk.com/view/INVNTOR/2021/ENU/?guid=GUID-CC72C68D-0212-4351-ACEE-DB7577B3EF69
Many thanks!
Message 15 of 15
IgorMir
Thanks, Johnson.
You see - people on this forum were calling out for years for contributors to the forum to indicate - what version of Inventor they use and what version of Inventor their attached parts are. What do we have still? The same as twenty years ago. 🙂
Cheers,
Igor.
