Arc Dimension
Arc Dimension
Victor.Tuguinay
Arc Dimension
Victor.Tuguinay
Is there a way to create the arc dimension to a certain angle in inventor? For example, the arc dimension from 0 deg to 25 deg  which is 1017mm as shown below. That is measured along the shell of the tank.
blandb
Just for clarity, are you wanting this on a drawing? If so, do get things like this in the past, is I have created a sketch on the view, projected the edges, and made the arc to where I wanted it. Then I was able to dim just that in the drawing.
In the part, you can control by just doing an arc segment to the desired line.
Hope that helps.
Autodesk Certified Professional
