I cannot get a "mesh" appearance to show in the drawing in order to be exported to PDF.
I can select raster view and see the detail but rastered views do not export to PDF.
Not sure is there is any simple resolution to this issue?
Can you post the ipt/idw files?
Just an example with that mesh appearance applied to it would be fine if you don't want to share that exact part..
Hi Phillip,
This one should be easy. Edit the view -> Recovery tab -> check Include mesh objects.
Many thanks!
Hi Phillip,
Many thanks!
@johnsonshiue wrote:
Hi Phillip,
Many thanks!
@johnsonshiue They seem to have an appearance that looks like mesh.. Its not a mesh 3d object.
Hi Phillip,
Many thanks!
