API to extract BOM data from Inventor File to text file
Hi, I am an ERP system developer, looking to create an API to extract the BOM data from an Inventor file into a text file to import into my ERP system.
Where is a good starting place to learn the basics?
Thanks,all.
pball
There is a code example in the Programming/API Help. Search for "BOMQuery" and a sample for creating a BOM list will come up.
You can also look at my implementation of that sample at the thread below.
https://forums.autodesk.com/t5/inventor-customization/vba-counting-quantity-of-parts-in-assemblies/t...
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Thanks!  This code looks straightforward, but, being new to CAD, I'm trying to locate the API under tools, but it is not there - is this an add-in?  Where can I download it.
Again, thanks much for the help!
Curtis_Waguespack
Hi khayesNS46V,
See this link:
Autodesk Inventor Developers Network info:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1079044
And note that you can search and ask programming questions of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
