Can someone please explain how I can split this into multiple parts so that I can have different engineering drawings for each part. Want this manufactured.
Thanks.
Solved by swalton. Go to Solution.
Workplanes and the Split command to break it up into solids that represent the various parts you want.
Then use the Make Components workflow to push the solids out to individual parts and an assembly.
Steve Walton
I don't know of a straightforward way without a little tedious effort, mostly using the Split tool. Attached is an example of one way you could break it up. (Not sure what version of Inventor you're using, this is in Inventor 2017).
