any way to rotate dimension line like autocad?
jetlau2001
Message 1 of 12
jetlau2001
Hi, everyone, m wondering is there anyway to rotate an aligned dimension in Inventor drawing like autocad?  please see the image below(the red arrow one is waht I want).  or is this could be done by coding with C#? Appriciate any help. Thanks.
Replies (11)
Message 2 of 12
gmarken
You can sort of get that look when dimensioning an isometric view. Although, what value is there in dimensioning that way?
Message 3 of 12
jetlau2001
My supervisor asked to dimension like that. 😂. so the answer is "No".  I can not rotate an aligned dimension like autocad in inventor 2D plan view, right?
Message 4 of 12
jetlau2001
My supervisor asked to dimension like that. :face_with_tears_of_joy:. so the answer is "No". I can not rotate an aligned dimension like autocad in inventor 2D plan view, right?
Message 5 of 12
Gabriel_Watson
Click and drag one end point of the dimension, where it touches the arrow:
Message 6 of 12
jetlau2001
thanks a lot.  one more quesion, can I constrain the dimension line to keep it absolutely horizental?
Message 7 of 12
Gabriel_Watson
That's the bad part.... I don't think there is an automatic way for that.
I just zoomed in as much as I could and tried to eliminate bumps/steps on the horizontal extension line to make it as flat as possible.
Message 8 of 12
JDMather
Wait a minute.
Are you trying to dimension the vertical height
or
are you trying to dimension the Aligned length?
Can you attach your *.ipt file an drawing file here?
Message 9 of 12
jetlau2001
m trying to dimension the aligned lenghth, then rotate the dimension line to horizontal.
Message 10 of 12
JDMather
@jetlau2001
I went back and read the original description again and now I understand your intent.
What Standard does your company use (ANSI/ASME or ISO or other)?
Message 11 of 12
jetlau2001
actually m use a company standard based on China Standard.
Message 12 of 12
johnsonshiue
Hi Folks,
I would like to double-check and see if the "Rotate Dimension" is about the ability to align the dimension to a view edge. If yes, it is available as of 2021 and later. The exact term in AutoCAD is called "Rotated Dimension", which means a dimension is aligned to a selected linear reference.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Inve...
Many thanks!
Software Test Engineer
