Inventor Forum
Anti-aliasing: correct NVIDIA settings and driver
39 REPLIES 39
Message 1 of 40
whunter
4171 Views, 39 Replies
whunter
Hi all;
1) Settings issues:
I'm trying to get rid of jaggies in Inventor via the NVIDIA Control Panel by setting the display to Quality with the slider, but I don't see any difference in Inventor's display. Notes: I kill Inventor before I change settings, and then launch after I've applied the settings (but I don't restart, should I?). I have my display in Inventor set to Smoother. I'm using Vista, so it's D3D, no OpenGL.
Can someone give advice on how to get the anti-aliasing to work, please? Is there a 'benchmark' screenshot of one of the Inventor samples available somewhere so that I can compare? Maybe mine isn't so bad...
2) Driver issues:
Card: Quadro FX 570
Driver: 191.00_Quadro_win7_winvista_32bit_english_whql
The above is the latest driver from NVIDIA. www.inventor-certified.com gives 182.46 as tested driver, but I thought the whole point of WHQL is that any WHQL driver will work? Should I rather use the driver from inventor-certified?
There are similar posts to this one on this forum, but no satisfactory answers.
Cheers,
wh
Hi all;
1) Settings issues:
2) Driver issues:
Card: Quadro FX 570
Cheers,
wh
39 REPLIES 39
Message 21 of 40
NeilClasby75
in reply to: whunter
NeilClasby75
Hi WH
Glad I sort of helped? 🙂
Did you get it going with D3D9 or D3D10?
Cheers, Neil.
Hi WH
Cheers, Neil.
Message 22 of 40
MattH_Work
MattH_Work
Darn it.
DX9 - Good
DX10 - BAD
MattH
MattH
Product Design Collection 2025
Vault Pro 2025
Darn it.
DX9 - Good
DX10 - BAD
MattH
MattH
Vault Pro 2025
Message 23 of 40
whunter
whunter
Neil;
9 only, and 10 is the recommended setting for Vista... How do you figure that?
Do you have the details of the NVIDIA cards you applied your 'fix' to, please? I'm in discussion with the guys at Autodesk and it would greatly improve my case.
William
Neil;
William
Message 24 of 40
MattH_Work
MattH_Work
Latest News
178.26 - Good
MattH
MattH
Vault Pro 2025
Latest News
178.26 - Good
MattH
MattH
Vault Pro 2025
Message 25 of 40
richiesuk
richiesuk
is it ok with xp 64 bit?
Message 26 of 40
richiesuk
richiesuk
Message 27 of 40
DarrenP
DarrenP
vista supports direct X 9 & 10
you have to have a direct 10 graphics card to use it
win 7 supports direct X 9, 10, 11
DarrenP
DarrenP
Message 28 of 40
whunter
whunter
> {quote:title=DarrenP wrote:}{quote}
Yes, but that doesn't mean the anti-aliasing (aka multi-sampling) works. I have a D3D 10 card, but multi-sampling only works for 9 under Vista, and then only for certain NVIDIA drivers (see the ones MattH has tested thus far). What is more, my graphics card "Autodesk Inventor Certification Status" is Gold and according to
> {quote:title=http://www.inventor-certified.com/graphics/:}{quote}
>"If the D3D driver is WHQL certified, but reported as Uncertified or Unknown in the graphics diagnostic, Click OK and paste into notepad. Search for the word "Gold" in English.If it is found, everything is OK."
But obviously everything is not OK.
XP-64 only uses D3D 9 (aka DX9) (http://www.inventor-certified.com/graphics/#3GB_OpenGL)
Message 29 of 40
whunter
whunter
An official response to me from the Autodesk Support Team and developers state that for current (2010 SP1) and prior builds of Inventor, only DX9 will work to enable anti-aliasing from the NVIDIA control panel. DX10 doesn't work for Vista.
They said that will try to improve this in later builds of Inventor. Whether this means a setting inside Inventor or from the NVIDIA control panel is not clear.
So there you have it. DX9 only for Vista if you want anti-aliased display.
RIP
RIP
Message 30 of 40
NeilClasby75
NeilClasby75
Hi WH
In response to a previous reply, my card is an NVidia FX2500M in a Dell M90. The video driver is 156.69 with BIOS 5.71.22.28.04.
Not sure how much different 9 is to 10? Faster I guess? Is this something to look forward to?
I also assume that Windows 7 makes no difference as DX is effectively a separate standard anyway - therefore you would have to use DX9 in Window 7?
For the record (to Autodesk) I would say that anti-aliasing is up there as one of the most vital and important issues to be resolved. My week is anything from 50 hours to 110 hours, which is a long time staring at a screen. I simply could not do this without anti-aliasing as without it the lines appear to flicker. Assuming the newer DX standards are faster then this simply makes the use of them even more important, as we all strive to get the maximum performance from our workstations to improve both the quantity of our work, but also the quality of the environment (i.e. Inventor) in which we work. PS Inventor is the bestest thing ever!! 🙂
Hi WH
Message 31 of 40
whunter
whunter
Hi Neil;
We seem to be only a handful of people who actually make use of multi-sampling. I suspect many users are still on XP, so they have the OpenGL option, or they just don't worry about it/doesn't bother them.
For me it's also essential for the same reason as yours. I also write technical reports and often take screen shots of parts/assemblies for documents (I know there are other ways, but taking a screen shot with Vista's little Snipping Tool is very productive). An anti-aliased picture just looks so much better than a jagged edged thing...
About W7, it won't be any better. W7 is just a (much needed) improved Vista, as I understand. Anyway, I read good things about W7, so will definitely make the switch (UAC is driving me mad).
I had to create an issue as a Subscription Member to get an answer I was happy with, I recommend you do the same. It's the only way to address the issue, one can't, in all fairness, expect the ADSK developers to browse forums looking for issues. BTW, I got prompt and to the point support from the Autodesk Support Team.
Hi Neil;
Message 32 of 40
MattH_Work
MattH_Work
Latest News
178.46 - Good
181.20 - BAD
So it seems that 178.46 is the latest driver which supports AA when run with the Quadro FX 570
Hopefully either NVIDIA will put back in whatever they took out, or Autodesk will officially support AA in the future (SP2 ?)
MattH
MattH
Vault Pro 2025
Latest News
178.46 - Good
181.20 - BAD
MattH
MattH
Vault Pro 2025
Message 33 of 40
ToddHarris7556
ToddHarris7556
Sorry... feeling a bit confunded at the moment....
I'm also running an FX2500M / M90. Just recently installed Win7/64 and moved my Inv 2010 Pro to it.
Let's just say.... there are lots of challenges with the video. It's fine until I fire up Inventor, and then... flash/tear/jaggies... wow.
Driver Version (in the Adapter properties window) is 7.15.10.9746, with BIOS 5.71.22.28.4.
Dell hasn't yet posted a Win7 driver for this, and NVIDIA says 'go see Dell'.
Where do I find the 156.69 driver, please? Or any more recent driver?
Many thanks in advance.
Todd
Dell M90 4GB Win 7/64
Dell 670 8GB Win XP/64
Inventor 2010 Pro SP1 / Sub Bonus / iLogic
Todd
Product Design Collection (Inventor Pro, 3DSMax, HSMWorks)
Fusion 360 / Fusion Team
Todd
Todd
Message 34 of 40
Thank you MattH and whunter!!!! And anyone else! I have been trying to get this to work forever.
It looks phenomenal with AA on!! I have it set at 8x (4xSS,2xMS) This is why you pay extra for the Quadro cards! Otherwise you might as well stick with onboard graphics.
Shame on Autodesk for not having better AA support and shame on nVidia for not having drivers that have functioning AA for the last year! (AA didn't work in another program MeshLAB that I use before either and now it does) Hopefully they correct this soon. But for now I'm sticking with DX9 and 1yr old nVidia drivers!
Thanks Matt and Whunter again!
P.S. In 2D drawings this is especially great. They had wicked jaggies before. It was driving me crazy that with a $500 video card and $5000 software I had to deal with that!!
...And screen captures finally look professional.
Message 35 of 40
whunter
whunter
> {quote:title=jason7550 wrote:}{quote}
Glad I (we) could help!
Apparently you can't override DX10 via NVIDIA control panel settings, DX10 gets its instructions from the application (in this case Inventor). DX9, on the other hand, allows its settings to be set by NVIDIA control panel. So it is completely up to the software engineers at ADSK to make AA work with DX10. It is therefore not the graphics card vendor's responsibility (to the extent mentioned here).
It means they'll (ADSK) have to add an Infinitely Smooth option or an Anti-aliased or Multi-sampling option to Inventor. Anyway, this is my laymen's way of understanding it... And of course, don't forget that with Vista and W7, OpenGL isn't an option, like it is with XP.
As I understand from an ADSK employee, AA will be 'better' in future releases, I hope this yields something to cheer about.
Message 36 of 40
On 11/19/2009 12:13 PM, whunter wrote:
> > {quote:title=jason7550 wrote:}{quote} > Thank you MattH and
> forever. > > Shame on Autodesk for not having better AA support and
> I'm sticking with DX9 and 1yr old nVidia drivers! > > ...And screen
> captures finally look professional. Glad I (we) could help! Apparently
> the extent mentioned here). It means they'll (ADSK) have to add an
> and W7, OpenGL isn't an option, like it is with XP. As I understand from
Yes update soon and often as the best is yet to come! Sounds like an ad
doesn't it? I'm rather new to IV as I was stuck in ACAD for the last few
years, and the things I had to correct for there still haunt me! I was
trying to rotate a block in AutoCAD 2010 yesterday by using grips and
second space bar gets to rotate. IT WON'T rotate and show me a visual
rep. until I exploded it.
Message 37 of 40
richiesuk
richiesuk
any news????
any news????
Message 38 of 40
mcgyvr
mcgyvr
> {quote:title=richiesuk wrote:}{quote}any news???? Hopefully this is being addressed in 2011....:) you can sign up for the beta to check for yourself.
Message 39 of 40
whunter
in reply to: mcgyvr
whunter
Well, this is now good in 2011, just set to Quality under the Hardware Tab. Happy, thanks.
wh
wh
Message 40 of 40
richiesuk
richiesuk
Hi all,
we have latest certified nvidia driver, win 7 x64 inv 2011 pro, and cant set up visual type 4 and neither AA....
any suggestion?
here is the hw report
This Direct3D graphics driver is not Microsoft WHQL certified
Graphics Hardware Description:
NVIDIA Quadro FX 1800
AIRViz Device Manager \ VirtualDeviceDx9
Feature Level 3_1
Hardware Renderer
Graphics driver file nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um is version 8.17.12.5849
Current optimization settings are not known
The display is using 32-bit color
Inventor Version:
Build: 239, Release: 2011 RTM - Date: Wed 02/17/2010
64-Bit Edition - 8192.00 GB
Loaded Inventor Add-Ins:
Routed Systems: Tube & Pipe
Assembly Bonus Tools
iLogic
Simulation: Dynamic Simulation
Autodesk Mold Design
Inventor Vault
Simulation: Frame Analysis
Content Center
Inventor Studio
Design Accelerator
EDM Addin
Frame Generator
AEC Exchange
Routed Systems: Cable & Harness
iCopy
Content Center Item Translator
3DxInventor
Drag & Drop Interoperability
Inventor Tools
Simulation: Stress Analysis
Autodesk DWF Markup Manager
System Information:
Operating System:                          64-bit Microsoft Windows 7 Professional  (Build 7600)
Language:                                           English
System Manufacturer:                  Workstation Specialists
System Model:                                                 WS14xx
BIOS:                                                     Default System BIOS
Processor:                                           Intel(R) Core(TM) i5 CPU         670  @ 3.47GHz (1 processor, 2 cores, Hyperthreading enabled)
System Memory:                                             7.991 GB RAM
Graphics Device Information:
Renderer:                                           HAL
Manufacturer:                                  NVIDIA
Chip Type:                                           Quadro FX 1800
DAC Type:                                           Integrated RAMDAC
Graphics HW Memory:                  768 MB
Display Mode:                                   1680 x 1050 (32 bit) (59 Hz)
Graphics driver file:                         nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver file version:                           8.17.12.5849
Driver Date:                                        9 June 2010 0:00:00 UTC (Coordinated Universal Time)
Direct3D Graphics Device Information:
Adapter Description:                      NVIDIA Quadro FX 1800
Vendor ID string:                              0x000010de
Device ID string:                               0x00000638
VendorID:                                           10de
DeviceID:                                             638
SubSystemID:                                    62c10de
Revision:                                              a1
Direct3D 10 / DXGI System Information:
Dedicated Video Memory:          742 MB
Dedicated System Memory:       0 MB
Shared System Memory:                              3.500 GB
DxDiag System Information:
Operating System:                          Windows 7 Professional 64-bit (6.1, Build 7600) (7600.win7_gdr.100226-1909)
Language:                                           English (Regional Setting: English)
Processor:                                           Intel(R) Core(TM) i5 CPU         670  @ 3.47GHz (4 CPUs), ~3.5GHz
System Memory:                                             8192MB RAM
Page File:                                             3041MB used, 13320MB available
DirectX Version:                               DirectX 11
DxDiag Version:                                6.01.7600.16385
DxDiag Graphics Device Information:
DirectX Version:                               10.0
DDI Version:                                       10
DDI Version Number:                     a
DxDiag WHQL Level:                       0
Driver Signed Valid:                         True
Driver Signed:                                    True
Revision:
Graphics HW Memory:                  229 MB
Display Mode:                                   1680 x 1050 (32 bit) (59Hz)
Driver file version:                           8.17.0012.5849
Driver Date:                                        6/9/2010 18:49:00
WHQL Level:                                      1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Graphics driver log information:
Jun/29/2010-15:53:49:   User changes the graphics driver by reading XML file: D3D10 -> D3D9.
Hi all,
any suggestion?
Feature Level 3_1
Hardware Renderer
Inventor Version:
iLogic
Inventor Vault
Content Center
Inventor Studio
Design Accelerator
EDM Addin
Frame Generator
AEC Exchange
iCopy
3DxInventor
Inventor Tools
System Information:
Language:                                           English
Renderer:                                           HAL
VendorID:                                           10de
DeviceID:                                             638
Revision:                                              a1
DDI Version:                                       10
Driver Signed:                                    True
Revision:
WHQL Level:                                      1
