Annotating text to a part bubble
Good morning,
Is there anyway to annotate text to a part bubble so that if I had to relocate the bubble the text moves with it?
mcgyvr
What specifically are you trying to do?
Can you show an example..
The answer will change depending on the specifics of your requirement..
kelly.young
Autodesk Support
Autodesk Support
@Anonymous a simple way to achieve this is to create a leader on the bubble edge, the second click just click the exact same spot without extending the leader, type your info, it will create a text without showing the leader, when you move the bubble the text moves with it.
Please select the Accept as Solution button if a post solves your issue or answers your question.
I had tried your suggestion and it work perfectly for my applications.
Thank You!
