Inventor Forum
Angular greater than 180° and arc length dimension
3 REPLIES 3
VizCon
1690 Views, 3 Replies
VizCon
How to make Angular dimension greater than 180° or a arc length dimension?
See attached pic.
See attached pic.
3 REPLIES 3
Mark.Lancaster
in reply to: VizCon
Mark.Lancaster
@VizCon
I could be wrong but I don't think you will be able to create a dimension of 180..  Why do you need it dimension at 180 instead of 90?  Just trying to understand you requirements.
For the arc length, start a dimension, select the arc (now a radius dim is started), right mouse click, select dimension type and pick arc length.
Mark Lancaster
@VizCon
Mark Lancaster
VizCon
in reply to: Mark.Lancaster
VizCon
Oh I forgot the arc length dimension in 2D sketch. I use 3D sketches and don't have the arc length dimension available. Thank you for remind me, I think I can find a workaround now. 🙂
mslosar
in reply to: VizCon
mslosar
If angle dimension went over 180 degrees they COULD be used for radial dimensions.
Additionally, there ARE times you're trying to show someone that you need to go a certain direction and you'll need to rotate something, say 225 degrees to get there. There are other reasons as well.
