Angle of a cone
Angle of a cone
bullit2312
Angle of a cone
bullit2312
I have a model of a hopper / silo sent from a supplier. How do i find the angle of the cone by using the inspect / measure command?
I want to do this from the .ipt or .iam file and don't want to create a drawing file to do this.
Thanks in advance.
j.palmeL29YX
It depends on how the cone was modelled/created. If it is a rotated triangle, open the sketch. Here you can measure the angle. If it was modelled by another method, you can measure the height and the radius of the base circle. Then you have to calculate the angle: atan(Height/Radius).
cadder
Jürgen Palme
YannickEnrico
Or create a plane in the middle and measure the sketch after projecting cut edges
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
bullit2312
thanks for both replies.
