Amd vs Intel
Amd vs Intel
Amd vs Intel
Hey ! Will an Amd Ryzen 7 3700 run inventor properly? I read a lot about older versions of amd which had some problems with inventor.But what about the latest cpu‘s?
Thank you
leowarren34
Hi @Anonymous,
The Ryzen 3700 will be absolutely fine, I've seen some excellent Inventor Bench results from it's little brother the 3600. AMD has really started to compete with Intel and they are currently the best value for money at this moment in time.
I'll attach a couple of links;
This links to the Inventor Bench Mega Thread: https://forums.autodesk.com/t5/inventor-forum/how-fast-is-your-inventor-pc-really/m-p/9419365#M78388...
This links to TFI's Lower Cost Ryzen Build for Inventor: https://www.youtube.com/watch?v=FPFIq86Fw3k
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
mdavis22569
The CPU is newer ...
Ryzen 7 Pro 3700 September 30, 2019 OEM
You shouldn't have an issue at all
What are you other PC's specs?
Here is a side by side of this CPU vs Intel i7 8700
https://cpu.userbenchmark.com/Compare/Intel-Core-i7-8700K-vs-AMD-Ryzen-7-3700X/3937vs4043
Mike Davis
