All planes, etc suddenly visible?
WillL84
WillL84
I was editing this frame and this member specifically. All I did was delete a hole. Now it seems the origin, every plane, axis, sketch etc are all visible and I don't know how to get them to go away. I tried using the undo feature to undo the hole deletion but the items are still all visible. Any ideas?
Windows 11 Pro 64-bit
Inventor 2026 (PDMC)
TITAN Computers C161
i7-11700K/32GB RAM/Quadro RTX A4000
kacper.suchomski
Hi
This is not the origin, just the center of gravity, available on the view tab.
The view representation may be responsible for the remaining work items.
Kacper Suchomski
WillL84
I went into the view tab and the COG is not selected. Selecting it then deselecting it changes nothing. However under object visibility everything was checked somehow. I unchecked everything and now the COG still remains even though it's not selected. I'm not sure why all of those things were checked, I didn't change anything in the view tab. All Id id was delete a hole in this part. There's also nothing under the view representations for this part or the main assembly.
johnsonshiue
Hi! This could be a corrupted Design View Rep. Go to Manage -> Rebuild All -> save, close, and reopen. Does it work better now?
Many thanks!
Software Test Engineer
WillL84
I closed inventor last night and when I reopened the model this morning it was back to normal.
