Alignment profile using Frame Generator
QESRL5681
QESRL5681
Hi everyone, and happy new year!
I have an issue with profiles allignment, on the attached file.
On the sketch, try to change the angle from 90° to 220° and verify what appens to frame alignment. Then go back to 90° and check again.
The only “solution” that I’ve found in order not to change the alignment is to reach 220° by multiple steps of 30/40°…
What I am doing wrong?
Thank you for your cooperation.
Paolo P.
bhavik4244
@QESRL5681
As long as I can see you have projected verticle plane from where you made angle dimensions and when you change it went to another quadrant.
I have redefined that line and change the way of dimensions which you can see in the attached screencast. this way if you enter a counter-clockwise angle it won't get the wrong quadrant. I hope it answers your doubt 🙂
Bhavik Suthar
