I am fumbling around with this desk leg assembly. Specifically the lining up the leg to the support. I cant figure out the contraint/plane to use and overall have a feeling i am going about it all wrong. any suggestions would be of great help!
picture and .iam attatched
Solved by johnsonshiue. Go to Solution.
You need to attach the .ipt files with your .iam.
From a quick look, don't create the workplanes in your assembly for this.
Another option, create it all in one part and then turn that into an assembly, pattern the legs.
Hi! I suggest you insert an UCS and then constrain the cylinder to the UCS. It will help you position it more easily when there is lack of reference geometry.
Many thanks!
