Is there a way to align the center marks with the center line originating from the center of the part?
Solved by swalton. Go to Solution.
One way is to add a centerline between the centermark in each hole and the centermark at the center of the part.
Or, if you have at least two holes that are on a bolt circle about the part center, you can create a "Centered Pattern" centermark set.
Steve Walton
