My currently assembly is at an angle wrt to the origin planes. I want to align the assembly at zero angle or mate the component with xy plane.
What option should i select?
Solved by Gabriel_Watson. Go to Solution.
Constrain > Mate > Flush (0.00 offset) ?
You can do similarly with any subassembly inserted into a top assembly. Just make sure your component (assembly or part) you constrain is not already "Grounded" (right-click and un-check "Grounded" option).
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
