I'm looking at a workflow where I need to emboss various logos on the circular "tip" of a basically cylindrical piece. So, I can make vectors and output dxf in Inkscape as described here but when it comes to aligning them to Inventor geometry I'm faced with a rather tedious and unreliable process. For instance, I can move the various paths relative to circle center but I can't make them all equidistant from circle center, because they're far from uniform and selecting them all at the same time doesn't align things accurately either. The "project underlay" system doesn't seem to work on DXF, only DWG, The best I can think of is enclosing the whole logo in a circle in Inkscape or enclosing the individual shape in circles. Does anyone have any other suggestions?
Solved by jtylerbc. Go to Solution.
I'm not absolutely sure I understand the question, so this may not be quite what you're looking for.
What about grouping the objects that make up the logo together as a Sketch Block? Then the whole logo will move together as a single item, and can be constrained as necessary to position it without messing up the geometry of the logo.
On another note:
If you already have a DXF, you're one "Save As" in AutoCAD away from having a DWG. So if an underlay would solve your original problem, it shouldn't be hard to make that happen.
