Align Subsequent Feature Control Frames
ethan_howardMMXXV
ethan_howardMMXXV
Hello Community,
Is there a way to align the lower frames to the first? Currently, they are green "snapped" to the one above so if I move them, they move as a group.
Thank you!
Autodesk Inventor Professional 2022
64-Bit Edition
Build: 287, Release: 2022.2.2 - Date: Fri 02/11/2022
CGBenner
@ethan_howardMMXXV
They seem to be centered.... check the Feature Control Frame style, and see if the text justification associated with it is set to Center.
Did your question get successfully answered? Then just click on the 'Accept solution' button.
Let us know how we did on Trustpilot.
Thanks and Enjoy!
Chris Benner
ethan_howardMMXXV
@CGBenner The feature control frame style was centered. I created a new style from the existing and altered the text to left-justified without any change. I think it has more to do with the centered green snap. I may have to create this using a Leader Text?
ethan_howardMMXXV
I disconnected all the green snaps and eyeballed it. If I need to move it, then I have to remember to grab everything. Not perfect but it is a workaround.
CGBenner
EDITED
@ethan_howardMMXXV I found it I think.  In the Style Manager for Feature Control... check Cell Alignment, Datum Alignment and (if you want) Leader Attachement... to control how things line up in a stacked situation.
Thanks and Enjoy!
Chris Benner
ethan_howardMMXXV
@CGBenner close but no cigar! Leader Attachment is exactly that.
Datum alignment does this:
Thanks for trying! Appreciate it!
