Align in assembly
Align in assembly
wagari.aboma68FYZ
Message 1 of 8
Align in assembly
wagari.aboma68FYZ
How to align centers of two cylinders which are on two different planes in inventor assembly?
For example the inlet connection and the filter in this case.
To make the problem a bit clearer, I want to align these two parts so that I can connect them by Pipe center to center in a 90 bent pipe.  If they are not aligned, the piping will go some other routes than simple 90 degree.
Replies (7)
Message 2 of 8
CCarreiras
HI!
You could do an INSERT Contraint to connect the elements + ANGLE Constraint to the position.
CCarreiras
Message 3 of 8
JDMather
@wagari.aboma68FYZ
Zip and Attach your assembly here if you can’t figure it out.  Someone here will demonstrate the process.
Message 4 of 8
Frederick_Law
Constrain center axis.
Select the cylinder and you can pick the axis.
You can flip the direction also.
Message 5 of 8
wagari.aboma68FYZ
@JDMather , Thanks for your comment but due to confidentiallity I cannot share the files.
Message 6 of 8
wagari.aboma68FYZ
@CCarreiras, Thanks for the comment. However, in my case the parts not need to be connected. They should be aligned so that I can connect them by 90 degree bent pipe.
Message 7 of 8
TheCADWhisperer
Make up a simple dummy assembly that can be used to illustrate your issue.
I can see from your screen capture what you need, but this is basic stuff that I think it would be more beneficial to you if you Attached a dummy assembly.
Message 8 of 8
anthonyzepeda1969
Turn on the planes and align the planes.
