AIUTO LIBRERIA INVENTOR - INVENTOR LIBRARY HELP
g_carbutti
g_carbutti
Qualcuno mi saprebbe spiegare come risolvere? Devo mettere dei cuscinetti sull'albero e dopo aver selezionato la faccia della sede dell'albero e poi la faccia dello spallamento, devo selezionare il fulmine a destra per aggiornare i cuscinetti. Però a me esce questa finestra.
[translated with Google]
Could anyone explain to me how to solve it? I need to put some bearings on the shaft and after selecting the shaft seat face and then the shoulder face, I need to select the bolt on the right to update the bearings. But this window pops up for me.
Sono andato quindi al Centro contenuti come citato nella finestra e la finestra risulta vuota, che dovrei fare?
I then went to the Content Center as mentioned in the window and the window is empty, what should I do?
johnsonshiue
Hi! It sounds that the Content Center or the particular standard of interest is not installed properly. Try this. Start a new assembly -> Place from Content Center -> try to pick a fastener or any standard part. Does it work? If not, it means the CC library are not available in the active project.
Then close all Inventor files and go to Project settings -> find the tool buttons on the right and click on the button at the bottom -> Configure Content Center -> make sure the desirable standard libraries are selected. Also go to Tools -> App Options -> Content Center -> Content Center Library. Make sure the path is correct and the folder contains the proper idcl files.
Many thanks!
Software Test Engineer
