Inventor Forum
Adjusted Length Cable & Harness
1 REPLY 1
282 Views, 1 Reply
Is there a way in the cable & harness to modify the adjusted length? As the round ups sometimes put the cable too high or too low. The length of the wire is shown as 2.71", but we want it to be 3.5" and when I do the different round ups I have gotten 3.25" or 3.75" but not 3.5". We want it slightly longer than the actual length due to the fact that it is attached to an NPT and it might not land in the exact spot the model shows when threaded in.
1 REPLY 1
mcgyvr
No not really outside of changing the wires routing..
There really isn't a valid way to fix/define the length of them.
You can change the wire routing, adjust the global slack %, change the roundup and you could change the authored pins strip length value to add more but thats it.
Technology Administrators
