Hello! ๐
I've recently started using tubing and piping in inventor. I've noticed that whenever I start a tube run and place the first piece of tube, I get the dimension of the length (in this case 52mm), and then I get an additional ''Driven dimension'' displayed like: (52).
What is this driven dimension good for? And if there is no use for it, is there a way disable them from appearing?
โThank you in advance ๐
Solved by matthew.hansche. Go to Solution.
I have used T&P extensively and I know that the Normal dimension is the user-input dimension (whatever length you defined in the route sketch). According to Autodesk the driven dimension is used for "dynamic updates" but I cannot say that I have ever worked with this feature (although I am sure others here have). To my knowledge there is no way to turn it off...
