Inventor Forum
adding to ordinate dimensions
8 REPLIES 8
Message 1 of 9
8934 Views, 8 Replies
I have had to revise a part that someone else created at some earlier date.
They used the ordinate dimensions, which works perfectly and looks good.
I have had to add some holes to this part, but can not figure out how to add more dimensions
to the existing ones, outside of deleting the dimensions and dimensioning them all over again.
How do I add more ordinate dimensions to the existing?
As always, thank you so much for educating me.
8 REPLIES 8
Message 2 of 9
Cadmanto
As long as you have the target starting point you should be able to just select the view and the destination point and it should reference back to the already existing target point.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 9
in reply to: Cadmanto
Thank you. I didn't realize that for the first new hole, I had to select the center rather than an edge like with the remaining holes.
Message 4 of 9
SBix26
It depends on whether they were placed as an Ordinate Dimension Set or as independent Ordinate Dimensions.  If it's a set (when you click on one it selects all of them), then right click on any one of them and choose Add Member.  If they are independent, use Scott's method.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
SpaceExplorer/SpaceNavigator NB, driver 3.16.2
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Message 5 of 9
Mark.Valenti
I must be missing something, can anyone walk me through the steps?
-Mark
i7-7700K @4.2GHz
32 GB Ram
Nvidia Quadro 5000
Message 6 of 9
mcgyvr
in reply to: Mark.Valenti
@Mark.Valenti Just right click on one of the ordinate dimensions in the set you want and select "add member" then click on the location/feature you want to add another ordinate dimension member to..
Message 7 of 9
Mark.Valenti
in reply to: mcgyvr
I figured as much, however....   http://autode.sk/2lg32UG
-Mark
i7-7700K @4.2GHz
32 GB Ram
Nvidia Quadro 5000
Message 8 of 9
mcgyvr
@Mark.Valenti Then they were created with the "ordinate" function with the origin indicator hidden and not an ordinate set..
So you just fire up the "ordinate" command.. Pick your view and select what you want.. It should honor the existing origin point..
Message 9 of 9
Mark.Valenti
in reply to: mcgyvr
I swear that wasn't working before.....  LOL  Thanks!
-Mark
i7-7700K @4.2GHz
32 GB Ram
Nvidia Quadro 5000
