Hi there !
So I want to add a new belt to the generator.
I don't know how to that, therefore I've searched the Internet and found this:
I don't have such a file within the Inventor 2017 installation folder.
The only file that could have to do something with it - you can see in the picture.
What am I doing wrong - did something change in Inventor?
Also, I do not understand the .xml file. It has path to not exisiting other .xml files.
Here is a ecerpt:
?xml version="1.0" encoding="UTF-16"?> <FDesign><Defaults IsDisabled="0" SolverOpt="1" Version="1"><Descriptor /><Path Valid="0" BLock="0"> <Belt CFFamily="SBelts\Belts\H-ISO5296.xml" CFMoniker="H:075:330" CFRevision="1.0" SizeDsn="330H075" StdLen="83.820000000000"> <Descriptor /><fmax Val="60.000000000000" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <v Val="3000.000000000000" Units="fps" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <SpcMass Val="0.000600000000" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <pb Val="1.270000000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <L Val="83.820000000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <a Val="0.068580000000" Units="in" Prec="-1" Err="0" Type="3" DataType="0" ErrId="0" Chng="-1"/> <a2 Val="0.058420000000" Prec="-1" Err="0" Type="0" DataType="0" ErrId="0" Chng="-1"/> <z Val="66.000000000000" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <H Val="0.355600000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <B Val="1.905000000000" Units="in" Prec="-1" Err="0" Type="3" DataType="0" ErrId="0" Chng="-1"/> <S Val="0.612140000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <Beta Val="0.349065850399" Units="deg" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <Ht Val="0.228600000000" Units="in" Prec="-1" Err="0" Type="3" DataType="0" ErrId="0" Chng="-1"/> <rr Val="0.101600000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <ra Val="0.101600000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <Dmin Val="5.000000000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <Ta Val="10000.000000000000" Exp="22,481 lbforce" Units="lbforce" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <Cl Val="1.000000000000" Exp="1,000 ul" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <Pr Val="5202761.154513889000" Units="hp" Prec="-1" Err="0" Type="3" DataType="0" ErrId="0" Chng="-1" Min="0.000000000000" Max="10000000000.000000000000"/> </Belt> <Pulleys><Object Class="CPSynchronousPulley" pOfst="0.068580000000" dNomW="1.905000000000" eFlng="0" CFFamily="SBelts\Pulleys\H-ISO5294.xml" CFMoniker="25H075" CFRevision="1.0" IntName="{B932146E-28D1-4C1A-9AC4-6010EC291D4D}" ePlace="0" eAct="0" eSgd="0" clcw="-1" eLoad="3" SizeDsn="25H075"><z Val="25.000000000000" Prec="-1" Err="0" Type="3" DataType="1" ErrId="0" Chng="-1" Min="3.000000000000" Max="999.000000000000"/> <pb Val="1.270000000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <D0 Val="9.969178886335" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <a Val="0.068580000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <bf Val="2.489200000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <rb Val="0.160020000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <rt Val="0.160020000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <bw Val="0.419100000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <hg Val="0.304800000000" Units="in" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <fi Val="0.349065850399" Units="deg" Prec="-1" Err="0" Type="1" DataType="0" ErrId="0" Chng="-1"/> <wf Val="0.127000000000" Units="in" Prec="-1" Err="0" Type="0" DataType="0" ErrId="0" Chng="-1"/> <hf Val="0.127000000000" Units="in" Prec="-1" Err="0" Type="0" DataType="0" ErrId="0" Chng="-1"/> <Descriptor />
Thank you very much!
Have a nice day!
Your's sincerely
My bad! I'm sorry this can be closed.
The answer is quite easy, I was looking in the wrong directory.
You'll find the files when you are looking for in ...\Users\Puplic (my directory was C:\Users\Public\Documents\Autodesk\Inventor 2017\Design Data\Design Accelerator\Tables\SBelts)
