Adding this dimension will over-constrain the sketch. Choose Accept to create
I would like to know with exactness, to finish understanding this message: Adding this dimension will over-constrain the sketch. Choose Accept to create a Driven Dimension.
I'm doing a geometry with measures already tested because I get this message, as I do to solve this.
Gracias y Saludos
Accepted solutions (3)
hosford
 Elder
The sketch you are adding the dimension to already has that portion defined by either constraints or other dimensions, although sometimes it is nice to have a dimension that references the sketch but is not drive able.
Thaddeus Hosford
NUC9i9QNX i9-9980HK, Win 10 Pro 64
Nvidia GTX 1650
Inventor 2021
TheCADWhisperer
@Anonymous wrote:
I would like to know with exactness...
If you would like to know with exactness - then Attach your *.ipt file here and end all doubt.
My guess, from only the image, is that you have a Coincident or Colinear constraint on the vertical line to other geometry in the sketch. (Perhaps an equal (=) on the horizontal, but I think you would know that one as it would have to be added manually.)
johnsonshiue
Hi! Indeed, the behavior is geometry specific. We need to take a look at the sketch in order to understand the behavior better. It could be working correctly based on the existing dimensions and constraints. Or, it could be a bug in the sketch.
Many thanks!
Software Test Engineer
Ranjan_Narayanan
Community Visitor
Community Visitor
Hi Johnsonshiue, How to resolve a bug in the sketch, My sketch cant constraint even though it displays degree of freedom, when it constraints it says over constrained, Some of them I dimensioned it to zero instead of constraints
johnsonshiue
Hi! Please share the file here or send it to me (johnson.shiue@autodesk.com). I would like to understand the over-constrained behavior better.
Many thanks!
