adding new revision style table into other drawings
rclement
Message 1 of 8
rclement
ladies and gents
I created a new revision style table along with customized note and label text
and was wondering how to import them into a existing drawing.
I know that with title blocks you can copy and paste into a drawing which is a time saver
was wondering if I could do the same with a new revision style table?
I see we can export styles but when I go to other drawing I don't see where to import.
I don't want to redo for every drawing
Replies (7)
Message 2 of 8
johnsonshiue
Hi! There is a standalone tool called, Drawing Resource Transfer Wizard in All Programs -> Autodesk Inventor xxxx. You can push drawing resources from one file to several selected drawings.
Many thanks!
Software Test Engineer
Message 3 of 8
rclement
it worked with the title block but not with the new label and note text and the revision table
I gather I have to update the style library.
when you update the library does that library exist in a already
created drawing or do I have to change each one?
Message 4 of 8
johnsonshiue
Hi! Once you have updated the Styles Library, there is indeed a way to push the updated Library styles to individual drawings. Go to \SDK\ folder and install user tools. You will see a tool called Batch Update Styles in Drawing. It can help you push the styles from the Library to each document.
Many thanks!
Message 5 of 8
blandb
I don't believe I have heard of the batch update styles. That is nice, beats each user needing to "Update" the drawing when opened. ....Thanks!
Autodesk Certified Professional
Message 6 of 8
rclement
that's the beauty of the forums. no matter how much you think you know there's always more to learn
never ends
Message 7 of 8
rclement
thank you Johnson.your always helpful and I appreciate that.
Message 8 of 8
rclement
can you update one drawing at a time? do you have to save to the style library or can you transfer from one drawing to another? bypassing the style library?
