This has been a problem for a long time but I'm finally getting to the point where I have to stop finding work-arounds and address it.
I've made a sketch on a weldment assembly while in the machining environment that includes a number of points. I then use the hole feature to turn those points into holes in the weldment. Later I discover I need to add more holes to the same face so I add more points to the same sketch, and I edit the machining hole feature to include those new points. It gives me a preview of what I expect it to do, which looks normal, but when I click apply, the new holes are not added.
I basically cannot edit the number of extrusions that occur in a machining feature, I can only adjust the size and location. How can I fix this? Any help would be appreciated.
Solved by Gabriel_Watson. Go to Solution.
If new holes are on different parts, you need to include them in the feature.
Please attach a simple Weldment file.
Right-click the hole feature:
As @Frederick_Law says.
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
