adding multiple nut,bolt and washers
12:57 AM
I have an assembly with 2 plates with multiple holes in which i need to add a nut,bolt and washers to each hole. As the holes are in an irregular shape is there a way to add in a single selection?
Would you recommend the Bolt Connection feature?
If yes can Bolt connection be also saved as Custom so as to modify each nut,bolt and washer if required
The assembly is Inventor 2015
Best Regards
Richard
