Adding Multiple Fillets in Sketch Mode
RiggsMachine
Message 1 of 16
RiggsMachine
I often draw plates with many squares of varying sizes in them. Each square though has a .5 fillet in each corner.
It takes a while to click on each corner to add these features. Selecting a group of squares and choosing fillet
only adds (1) fillet to a random corner.
Is there a way to add a fillet to a selected group of object (2D sketch mode)?
-fitz
Replies (15)
Message 2 of 16
jeremy_wasserstrass
Is there a reason for the fillets to be put in in the sketch? There exist a couple ways to place several fillets at one time as a feature. There are 2 methods I use for that. The first is by using the Feature selection in the 3d fillet window (right hand side under Select Mode) followed by un-checking all rounds bellow it. The second method is with the Rule Fillet tool under Plastic Part.
Using Inventor 2026 on Windows 11
Ideas needing support: spur gear tooth profile, rack gears generator
Message 3 of 16
RiggsMachine
Once I've extruded the piece, if I select a group of squares, it wants to add fillets to the top faces (not the inside (4) corners.
I have not used 18 much yet. I'll look into that.
It's a flat plate with many squares, I just need the fillets in all corners.
-fitz
Message 4 of 16
JDMather
@Anonymous wrote:
...It's a flat plate with many squares, I just need the fillets in all corners.
-fitz
Can you do it the hard way and then attach the *.ipt file here?
Someone will then show you the easy way.
Message 5 of 16
RiggsMachine
Here is a complete item. Each one is different (the overall size and the squares).
-fitz
Message 6 of 16
TheCADWhisperer
First thing I notice is that there are a lot of dimensions missing from Sketch1.
When I add the missing dimensions - they come out perfect?
How are you sketching without dimensions?
I suspect Sketch Blocks and feature patterns might be very useful to you.
iFeatures might also be very useful.
Any time you see repeated geometry - there is usually an easier technique than sketching it bit by bit.
Message 7 of 16
RiggsMachine
It's all offset lines that are clipped. There were many dimensions. These fit individual units. I make many of them, each unique, but to specifications.
I can draw them quickly, I just need to add the fillets in either 2D or 3D quicker.
-fitz
Message 8 of 16
TheCADWhisperer
I will try to get around tomorrow to attaching an example using the Grill feature and Rule Fillet that will significantly reduce your workload.
Message 9 of 16
TheCADWhisperer
The Grill command might save you a lot of work.
(BTW - I grew up in Minerva, OH)
Message 10 of 16
S_May
please do that via ifeature, everything else is too slow (ifeature editable)
Message 11 of 16
RiggsMachine
That is fantastic! Thanks. I will give it a try this afternoon.
I really appreciate the time you put into that.
What did you use to record it?
-fitz
(we're in Ashland, KY - I design these for plants across the country).
Message 12 of 16
TheCADWhisperer
-fitz
Free Autodesk Screencast Recorder.
Message 13 of 16
S_May
Message 14 of 16
RiggsMachine
Yes, I can see creating a base model would make things go faster (on some units).
I will learn more about iFeature. thanks.
-fitz
Message 16 of 16
S_May
everything is possible for you now...
