I'm having trouble adding materials to my IAM file from inventor. I choose the material and then drag it to the section I want to color and the whole thing turns to that material, instead of just the desired section. I can't get it to stop doing this
The attached file is of a range hood, and I'm wanting to add a copper material to the cornerplates and apron.
Any help is greatly appreciated. Thanks!
well you say IAM then post an IPT..
But this is how you do it in the IPT..
Right click on a face and select properties.. Then pick the color from the list there. (face appearance)
And materials and appearances are 2 different things..
And obviously in the real world something like you have would be an iam (assembly) composed of multiple ipt (part) files.. not a single ipt file.
Within Inventor Materials and Appearance are two different things. Material is the physical property of the item such as mass and other physical attributes that are required for FEA. It has a default Appearance of "As Material". Then there is Appearance which is the color of the item which doesn't change the physical attributes of the item.
You can have a cube with "Steel" as the Material and have an Appearance of "Gold".
No on your model do you wish to have it out of steel with "copper painted" corners or do you wish to have additional items which are Copper as their material and a Copper finish. If this is the case, then you would need to place the base part within an IAM and then create Copper corner parts and constrain them to their correct locations on the range hood.
As posted you can RMB of the desired face or feature and select Properties and change this to get the desired finish. If you want part of a face to be different, you may need to use the Split-Face command to get the correct area on a face that can then be changed.
