Inventor Forum
Adding decal to surface, decal becomes mirrored
4 REPLIES 4
GustavStigsohn
1977 Views, 4 Replies
I am trying to wrap a decal to a cylinder surface. No mather how I place the image it always ends up mirrored. If I place the image on a plane in front of, behind or in the middle of the cylinder it always ends up mirrored on the cylinder surface. How do I solve this?
4 REPLIES 4
JDMather
in reply to: GustavStigsohn
Did you try right mouse button Flip Normal on the workplane?
Can you attach the file here?
GustavStigsohn
in reply to: JDMather
Tried fliping the normal, didn't help. Now I can't even attach the image to the surface...
File attached.
Edit: First ipt is a half cylinder. Second is a full cylinder. Half cylinder wont work. Full cylinder becomes mirrored.
salariua
Go inside the sketch, right click on the image in the browser, properties, mirror vertical.
You shouldn't need to do this but, it's working. You can also add transparency from the image if any with the use mask.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
GustavStigsohn
in reply to: salariua
Wonderful!
I must say, it wasn't the easiest to find.
