Adding column in i-logic form
All,
Again came here for some help. I want to add one or two column in i-logic form interface. For your reference i have added image. Please have a look and give me some suggestion on this.
Thanks in advance,
Kanagavel.M
Hello Kanagavel,
I totally understand what you mean, but I´m afraid the iLogic is very limited in styling the interface. I´m having the same issue that I can´t add multiple columns next to each other with titles above them like you can in Excel.
The only thing you can do is make a splitter with the toolbox of iLogic. But that only works for horizontal splitting.
If you have another solution, let me know aswell 🙂
Mark Roossien
You may also try, if you haven't already, adding rows:
Question, are you wanting these to somehow populate the same parameters? Won't they have there own cells? IF so, then yes, the guy showing the Dark theme is correct for you... 🙂
aronmatheus
There is a way to associate a dimension after the part number shows the form how this picture?
johnsonshiue
Hi! You are trying to make a dimension become part of the Part Number? If yes, it is doable with or without iLogic. Please share your attempt here. Forum experts can help take a look and provide further guidance.
Many thanks!
Software Test Engineer
aronmatheus
Yes, I'm trying to do this dimension to turn in link the BOM and show the part number form automatically, look how I did,  I don't like it but didn't  link
