adding a set screw in an assembly
How do I insert a set screw into the angled hole on the flywheel? The hole is on a curved surface. The set screw should be a DIN 915 M3 X 8.  I am using Inventor 2021.
mdavis22569
DIN 934 - M5 x 0.8  (can you share ... as I'm using a different Content Center)
However:
Maybe put an Axis constraint ... might have to then use a distance constrain from there.
Where do you want it in this model too:
Mike Davis
The set screw goes in the tapped hole in the flywheel. I've attached the right part.
mdavis22569
looking for this one:
DIN 934 - M5 x 0.8
Also can you share a screenshot ... but a quick look. You'll use 2 constraints
Mike Davis
Here's the screenshot. In my last post, I said the set screw should be DIN 915 M3 X  8.
mdavis22569
Like I was thinking ... thank you...
So this is how I'd do it:
https://autode.sk/2MGCFC8
*give it a few minutes to upload
Mike Davis
JDMather
Set "As Custom" to retrieve from library and place local so that others do not have to load library.
See my Attached assembly (and try rotating the crank).
Use Origin Planes for mating when possible.  (I got lazy on some of my mates - use (almost) all Origin geometry if possible.)
