adding a rib on a circular surface
rclement
Message 1 of 15
rclement
i am wondering if this can also be done in inventor
i also use solidworks and was adding a rib.seems you always get a straight portion
in the pink model.
but i was checking out utube to get rid of the straight portion which is done in solidworks by projecting lines on circular surface from flat surface then use the lofted boss base command to get rid of that little straight section shown in the gold model
lastly i saw a video adding adding a rib to three circular surfaces with inventor which you get those straight parts again
is there a way to get rid of those straight parts in inventor
Replies (14)
Message 2 of 15
kacper.suchomski
Delete face.
Kacper Suchomski
Message 3 of 15
JDMather
@rclement
Can you Attach your SolidWorks files here? (Export as STEP if  2024 version.)
Can you Attach your Inventor attempts?
Rest assured that this will be easy.
Message 4 of 15
rclement
DIDNT WORK
Message 5 of 15
rclement
could very well be easy but all the utube show it the same way
Message 6 of 15
kacper.suchomski
Yes, it easy works.
(view in My Videos)
Kacper Suchomski
Message 7 of 15
JDMather
@rclement
Your sketches are not fully defined.
I would not use your techniques in SolidWorks or in Inventor.
Are you willing to start over from scratch following my step-by-step instructions?
Message 8 of 15
rclement
what i want to accomplish is to get rid of a straight part in inventor.
i did solidworks old way and i get straight part. then i seen youtube video to get rib with a nice blend shown in autocad dwg right side
the other one is done in invenotr and i get straight part shown in left side of autocad drawing and would like to know if i can get a nice blend with rib to look like right side with inventor
Message 9 of 15
JDMather
@rclement
Yes.
This is a geometry problem - not a software specific problem.
It would be done exactly the same way in any CAD software.
(This is an interesting geometry problem that I first encountered 40 years ago out on the shop floor.)
Message 10 of 15
SBix26
While a blended rib looks nicer than a flat surface rib, aesthetics typically is not a significant consideration when producing machine parts such as this.  Inventor's Rib tool recognizes this fact by not offering a "blend" option.  Nevertheless, producing a blended rib is not so terribly difficult.  First technique that occurred to me is attached (Inventor 2024 format).  I'm sure there is an easier way to do this.
Sam B
Inventor Pro 2024.2 | Windows 11 Home 22H2
Message 11 of 15
rclement
actually is wasnt the rib command in solidworks  .it gave me the same thing as
inventor. but while i was searching for a way in inventor. i came across a new way in solidworks.
draw a sketch on flat surface use a command split line which projects onto circular surface
then use  lofted boss base. figured there was a way in inventor as well.i try to check out utube alot never know what you pick up there.
Message 12 of 15
rclement
 actually very well done
theres always another way may not be worth it
but always nice to know
Message 13 of 15
rclement
was wondering since your answer to the inventor rib was very impressive i was wondering if a could pick your mind again i came across another rib in one of the solidworks tutorials which work nice in solidworks but no so well in inventor. i had to break into 2 seperate extrusions first your way to circular surface then regular extrude command. was wondering if their was a easier way. i hope you dont mind me asking. i find you can always learn from someone else.
Message 14 of 15
SBix26
I'm away from my Inventor computer for several days, so someone else will have to tackle this one in the meantime.
Sam B
Inventor Pro 2024.2.1 | Windows 11 Home 23H2
Message 15 of 15
pinorelson19
Community Visitor
Community Visitor
I'm not sure if this method is acceptable.
