I am tryin to add more functionality to a existing content center part but i don't want to delete it and republish. I have a feature that needs to be suppressed depending on what a key column says. I can use logic if there is no other way but i prefer to keep it within the iparts table if possible
Solved by AMN3161. Go to Solution.
Hi! You do need to delete the family and republish it to CC library.
Many thanks!
Logic seems to be my solution then
If iProperties.Value("Custom", "End_Type_Key") = "SW Both Ends" Then
Feature.IsActive("SW_END_1") = True
Feature.IsActive("SW_END_2") = True
Else If iProperties.Value("Custom", "End_Type_Key") = "End 1 - Threaded"
Feature.IsActive("SW_END_1") = False
Else If iProperties.Value("Custom", "End_Type_Key") = "End 2 - Threaded"
Feature.IsActive("SW_END_2") = False
Else If iProperties.Value("Custom", "End_Type_Key") = "THD Both Ends"
