Add two base points to structural shape when authoring
matanT5LSH
matanT5LSH
Can I add additional base point to a profile I publish? so that I will have the default edges point, and more than 1 base points that I defined?
Ihor_Radikhovskyi
Currently, Inventor allows only a single Base Point per structural shape.
If you need multiple insertion points, the typical workaround is to publish multiple versions of the same profile with different base points.
Unfortunately, there is no native support for switching between multiple base points within a single shape definition.
matanT5LSH
