Inventor Forum
Add Radial Pin
5 REPLIES 5
479 Views, 5 Replies
Add Radial Pin
Hello Forum,
I cant seem to select an existing hole when I want to add a radial pin
Can someone help me?
Please
TIA
Haziq
5 REPLIES 5
Xun.Zhang
@Anonymous,
Are you talking about Harness -> Place pin?
If so, please select edge instead of surface.
else, could you help show more detail about your workflow, I am not quite sure about what you are talking.
Xun
in reply to: Xun.Zhang
I would like to use radial pin to attach the adapter and pendulum support together.
Sorry for not being clear the first time.
TheCADWhisperer
I noticed that some of your sketches are not dimensioned?
I noticed that you are creating Adaptive parts - is this what you really intended?
I noticed that you are creating multi-body solids - is this what you really intended?
Did you use Hole feature to create your holes, or did you use Extrude-cut circle?
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-A0994478-E81C-4FFF-A741-0E8C3EF5EE80
erdogan_isik
Re: Add Radial Pin
02-01-2018 10:45 AM in reply to: MdHaziq
Continue and...
Paylaşmak Güzeldir.(in Turkish), Sharing is beautiful.(in English)
http://www.eitasarim.com/forum
in reply to: TheCADWhisperer
Hello TheCADWisperer,
Thankyou for looking at my thread and replying.
1. I do not have all the dimensions with me so I am just drawing to get the idea out.
2. I changed my settings to draw adaptive parts. Not really knowing the purpose
3. I create in multibody solids because it is easier for me to fit them together. and yes it is intended. There should be a total of 2 solids but I went too far with it
4. I use extrude cut to create my holes which I want to use to create a pin though them.
   Now I know that I have to create a hole feature in order for me to create a radial pin through them.
   Is there a way for me to do it without redrawing?
TIA
Haziq
Do you have a website?
