Add Part from Productivity in Assembly - Incorrect units and unexpected zoom out
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've got two issues here in Inventor Pro 2018.1; one I need help with and the other is just a whinge!
In an .iam I'm creating several adaptive new parts. So I click on Add Part, from the Productivity section of the Assembly ribbon. I can browse to a folder, name it, wait for it to appear in my browser pane and start designing no problem.
However, the problem I have is that the part files are defaulting to using cm instead of mm, despite all our part templates having mm. The assembly has mm so it's not that either. I can't find any setting in the options that defines which template to use when using this work flow. Am I missing something? I've seen a thread on this forum from a few years back with a similar issue when creating simplified parts, so I suspect this is a bug, but the solution for that doesn't help here.
Secondly, (this is my whinge) after clicking to edit a new part, I choose Start 2D sketch but before I can click on the plane or face I want to sketch on, the assembly zooms out. It's not going to the home position (which we normally set to as Fit to View) because if I click on the home icon it shifts slightly. It is highly annoying though, because in a complex assembly and in the transparent state for editing in place, it makes finding the surface I want to sketch on very difficult. It's clearly not an issue with looking at a sketch plane on creation, as I haven't yet defined the plane. I can of course create a work plane first, (which is what happens automatically when I create a sketch first anyway) and I shall have to adapt my work flow to do this, but in the interest of reducing the number of clicks it would be better if we didn't have this zoom. Anyone else found this?
Kind regards
Steve
