Add in Frame
Add in Frame
Add in Frame
I've been designing a school project using Autodesk Inventor. I'm looking for some suitable frame for my project. I found out that the INSERT FRAME tab doesn't have the size and type I'm looking for, how do i update the frame in the library externally?
mcgyvr
Probably a question your teacher should be answering/teaching you on but..
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Mark.Lancaster
@Anonymous
Welcome to community...
You would first need to create a read/write (content center) library and then copy the information over to the read/write so that it can be modified..  Not sure of your school structure or if you are talking about this on your own PC but you may want to review these 2 articles (Article #1 and #2) plus the information @mcgyvr has sent you if you need to create your custom shape.
Mark Lancaster
