Inventor Forum
Add features to parent part but not to mirrored part.
4 REPLIES 4
hamzabuttX6GV8
309 Views, 4 Replies
hamzabuttX6GV8
Hi, Is there a way to add some features (e.g. holes) that are exclusive to the parent part and those features do not appear on the mirrored part? I don't want to break link of mirrored part to parent part because assembly is controlled through ilogic. When the overall size of the parent part changes, the mirrored part size changes as well so I can't break link.
Tags (1)
Labels (1)
4 REPLIES 4
kacper.suchomski
Hi
If you use the Derive tool, you can create one more derived component and perform further operations on it.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Hi
Kacper Suchomski
johnsonshiue
Hi! There isn't a workflow to do selectively associative on a per feature basis. I think using Delete Face -> Heal workflow in the mirrored part may help remove those features carried over from the parent.
Many thanks!
Software Test Engineer
Many thanks!
IgorMir
in reply to: hamzabuttX6GV8
IgorMir
iParts work very well for this case scenario.
Cheers,
Igor.
Web: www.meqc.com.au
Cheers,
Igor.
johnsonshiue
in reply to: IgorMir
johnsonshiue
Hi! Igor got an interesting idea. I would add on to that, Model States (2022 and later) may work for this case also. You will need to create a new Model State in the source part so that the part can have the additional features suppressed. Then derive the the particular Model State to a part.
Many thanks!
Many thanks!
